upgrading rims from 18s to 19s on a 96 toyota camry
sikwitit
hi everyone right now i have a set of 18*8 rims and tyres they stick out from the gards on the front i was going to trade them for a set of 18*7.5 but then i seen a nice set of 19*7.5s my question is when i lower the car will there be alot of rubbing scraping on the wheels when i lower it i have already rolled the gaurds any info is greatly appreaciated
sean
The rolling diameter should be the same regardless of the rim size
So what you want moving from 18s to 19s is the rim size to increase, and the tyre height to decrease.
thanks for that thats wat the problem is with my current wheels cause of the offset they stick out of the gards so i cant lower it so i need to find a set of rims with a +40 offset right
check your old rims see how much distance you with your brake caliper then chck the offset on your old rim if you can 45 or even 50 that should elimate you rubbing.im running 235/35 19s front & 255/30 19s rear 45 offset lowered 3,5 inches all around & i got no rubbing issues with a full car load.hope this helps mate
went and found out 2day i can get 19s on the cam with a +40 offset and 19*7.5 so now i just have to find some nice 18s lol just looked at how much most 19s cost so i think i will stick with 18s and also bit cheaper rubber was looking at
diamo 27 black rims 18s
http://www.talebtyres.com.au/products_clos...amp;part_no=576
http://www.talebtyres.com.au/products_clos...amp;part_no=577
http://www.talebtyres.com.au/products_clos...amp;part_no=422
http://www.stgeorgetyres.com.au/pap58.htm black
wat one do you people like
sean
i noe the hypnotics are 2200 for the 18s and 2700 for the 19s i quite like the black ice they are 1800 and hypnotic rims if i get the hypnotics i will get the red and chrome they look reali nice
still looking
sean
