Towing with my Kluger
cjdrakard
I have borrowed a friends trailer but the left hand indicator isn't working although the one on the Kluger is.
My friend assures me the indicator works when fitted to her car.
Can anyone tell me the pin configuration for a rectangle towing socket? I believe it to be a Toyota fitted item.
Cheers
Chris
The only way to truly prove the functionality is to plug it into her car, if it DOES work on there then start pulling your pins apart. I just went through this whole saga and it was a bad earth on the trailer. Bottom line test it on hers first or get a test lamp. $10 from auto stores.
