2014 Aurion exhaust replacement
Guspoe
Hi everyone, I have just joined the Aurion gang - but the car's got a dented left exhaust tip.
I wouldn't mind replacing it with an OEM or aftermarket - but I also don't want it to be too loud.
Do you guys have any recommendations on what I need to do (I am mostly trying to fix the aesthetics vs better sound) and what would be my cheapest option?
Thanks!
The pic isn't very good but you can see the left exhaust has a bend from hitting the kerb.
Would it be sufficient to just replace the exhaust tips at a workshop - and how much should I pay for replacing the exhaust tips?
Any suggestions are appreciated!
Edited by Guspoe
Yes they can cut and put a new exhaust tip on but you will need to do both side to make it match.
Alternatively you can get a second hand OEM muffler/tip at a wrecker and put in on.
Not sure on the prices but it shouldn't be too much. The whole muffler will be the easiest, even a mechanic or yourself can do it.
Edited by adn
