Hi, in the last week  my 2016 Landcruiser  has developed a starting problem.  Occasionally  it fires up ok but then shuts down after 5 sec of running . It can be restarted if I turn the car off  wait and crank it over for 20 sec. Local Toyota dealer found no faults or error codes. Has any one experienced the same issue ?
Check your fuel lines, especially the ones going in the fuel filter. Twist them see if they move. If so
replace the spring clamp with a screw type one solid band.
Hi Larry, thanks. Such a simple solution.
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
