vvti16v
    ZZE122R
    Sydney
4,046 profile views
vvti16v's Achievements
Mentor
Mentor (12/14)
  1. I'm after a supercharger kit for 1zz corolla
  2. Make me an offer !!!!1
  3. Make me an offer !!!!need to sell this
  4. Bump, still for sale and price drop..... $2800 posted within Aust.
  5. The kit is off the car now and is stil up for sale....
  6. Out of curiosity, what set-up did you have when this was on your car? Were you using the higher boost pulley? I was running low boost with 2.4in and depend on where you go for the dyno is between 106-110ATW Did you get a dyno reading for the set up? Besides the higher rated injectors, any other mods to the fuel delivery (ie rails or better pump?) upgraded the fuel pump to be safe, otherwise the same What kind of intake did you have on the charger? The kit comes with a custom intake Any changed to the bonnet clearence or did you have to get a ghey bonnet scoop or something? stock bonnet no mods
  7. can we please keep this clean? I'm trying to sell something here !!!!!!!!!!!!!!!!
  8. bump to the top.......
  9. Most people would know that my car is going back to stock and in the process of installing original parts back the rear swaybar was removed and it was broken at the welded joint....I have been getting a clunk noise when the car twist (going up driveways) and i though it was a loose bolt on the swaybar but it was a broken swaybar. So if people have the same noise you should check it.
  10. TRD Supercahger Package for 1ZZ: $3200 $2800.00 posted TRD SuperCharger with custom intake with 2.4in stock pulley(7psi) UDR 2.1in pulley (11psi) Sard 530cc injectors Toyota metal intake gasket (new) Power FC ECU with commander Custom air intake kit Custom battery relocation bracket for the air intake Still for sale......
  11. what colour u after?
  12. Hi all, please help, i sold my TRD short shift to a member but he thinks that the bolts are missing from the kit, i have not install this on my car because it is new but does anyone know if u use the original bolts or does it comes with new bolt to hold the bottom???? many thanks.
  13. hi there, With this package does it come with new screws ot u use the original ones. thanks
  14. Sounds like buying my TRD Supeecharger is the cheapest option :D :D :D
