adzz
    avensis
    2004
    Adric
adzz's Achievements
Progessing
Progessing (3/14)
  1. You don't need a transmission specialist you just have to be mechanical minded and should be able to do it the kit comes with instructions. You have to remove pan and valvebody open the valvebody do the mods and put is back in. The kit is $120 plus delivery about $10 anywhere in oz.
  2. You don't need a transmission specialist you just have to be mechanical minded and should be able to do it the kit comes with instructions. You have to remove pan and valvebody open the valvebody do the mods and put is back in. The kit is $120 plus delivery about $10 anywhere in oz.
  3. Sounds like low pressure to the converter I would try a new filter could be bit blocked up and put the kit in to raise the pressure I can supply the kit and filter pm me if you want can get them from transgo in the USA
  4. Hi guys I'm a transmission specialist from NSW thought I should share this with you guys. If you didn't know the a340 has a bit of a Lubrication issue and causes it to destroy the bearings in the torque converter. This causes you to blow the converter and the gear box especially bad when hauling weight. A new kit has come out to slightly raise the pressure so it doesn't shift to h**** but fixes the sloppy shifts this transmissions have especially when cold and also opens the oil feeds up to get the lube up to the pump and torque converter more. 9 out of 10 hilux 4 speeds I build need a new converter or costly repairs to the converter. It is getting very hard to find used ones as well and a new converter is around $1200 and really adds to the rebuild bill if you are unfortunate enough for this to happen to you. So heads up the kit is just over $100 a new filter while the pan is off and a external transmission cooler could save you thousands. Everyone I have fitted have been happy with the out come. Cheers guys
  5. Hi just thought I would say hi I am a transmission specialist from NSW with 8 years factory training so just put it this way I probably rebuilt a lot of you guys boxes if your from NSW let me know if I can help
