HI can anyone please help I have a 2002 v6 camry and have a problem with the check engine light staying on when I turn the ignition key on the abs light is flashing and the check engine light is on After starting the engine the abs continues to flash and engine light goes off when i drive away abs still flashes engine light comes on and there is no movement in the spedo after 10 minuits of driving engine light goes out and spedo comes alive and the autotransmisssion seams to work better I have used a scanner for error code reterival scanner reads no errors stored in car any help would be greatly appreciated Anthony
