ToyzR
    Aurion
ToyzR's Achievements
Contributor (5/14)
  1. does anyone know the paint code for a blue aurion? Thanks guys
  2. If these dickfaces are caught, their hand should be chopped... did u get your bonnet fixed up? and how much did it cost ya??
  3. Just to top everything off, i woke up this morning with a flat tyre. just came back from the servo, after pumping it. realised there was a pin hole on the side of the tyre. so that means my whole tyre is wasted. f##king $ankers!!!!!!!!! son of #itch knows what they're doing.
  4. Hi guys, parked the car on a side street, then went to work. Came back with extra 3 long white lines on the side, bonnet , and back of the car. Wanted to burn the whole #$%ing street down. Must be from one of those dickheads that thinks they own the car spot outside their house, on the street. Can't exactly explain how I feel at this moment. wondering if any of u guys know any good places that can do nice spray paints around the inner west area. Thanks guys.
  5. Good work mate, did u use S mode? which gear did u get up to?
  6. Hi guys, Just installed a pair of HIDs today. It looks sooo good............... Fully recommend you guys to install a pair. Plus they are really cheap these days, around 100 dollars .... I have always had HIDs in my other car.....they last around yr and a half. For a hundred dollars....not a bad investment.
  7. Thanks for that. Yeah im trying to run it off the stock head unit. Did u get a new unit? Thanks
  8. Hi guys, Im thinking of installing Amp and Sub into my ZR6. Used to have a tech coming around to do all my car audio work, just found out that he pass away last year in a car accident. :( I dont really want to have guys from Strathfield Radio or other ppl that i havent had experience with working on the car. Any tips on DIY ? or any tech that you guys may have used that is worth recommending it to me? ( inner west Sydney)?? Thanks a million.
  9. I know it gets a bit long winded but if you read back through all the posts on this thread, other people have had similar or even the opposite problem. One of the members claimed the economy wouldn't get worse than around 8.5L/100Km. Disconnecting the battery for 20 seconds or getting a dealer to reset the system (probably just disconnected the battery for 20 seconds or more <_< ) and the car started giving a more accurate reading. I think it should improve after your next service because of the grade of oil they apparently use for running the motor in. Even so, this is the exact same problem i've had since buying the car - really bad fuel economy. Hence the post about finally getting the car on the open road and taking a picture of what i thought was a myth. I have actually changed oil and filer already (toyota stock) that was done last week. So far there isnt any difference in terms of fuel economy. Let me try and reset the ECU when i get around to it, i will keep u guys posted.
  10. Hi guys, Im all enjoying the car apart for its fuel comsumption. Its doing around 13L/100kms, although not as high as some of numbers been mentioned in here, bit its so much higher than 9.9L/100. My ZR6 has less than 2000kms and i have never gotten below 11L/100km, i guess that is because i rarely hit highways. Just wondering has any body out there reseted the ECU and got an improvement? Thanks guys
