Harryshilux
2005 sr5
I was wiring a harness up and I connected battery before running wires through fire wall and I've shorted something out in my left hand lights no low beam or high beam just parked and I have no idea where the head light fuses are and because one side worked I thought it would be fine Harry's Hilux a bit troubled any advice would be thankfilull kind regards Mr Scott James Brown
