New Camry Altise (July07 build) became a Water Tank
zang_zy
Hi There,
I bought a new Altise last August. Three months later, large mount of water was discovered under the carpet in the boot. The covering boards under the carpet are soaking wet. The half of the spare tyre was in the water.
Checked the car at the Service Division, found the reverse parking sensor wiring grommet did not fit properly, and water could flow inside the boot whenever it rains. (It was raining a lot in Sydney during November!)
So check you car boot esp. if you have a reverse parking sensors fitted. It can be very dangerous if water affects car electronics.
Cheers,
zang_zy
Edited by zang_zy
Mate... I have the same problem... but my grommets should be fine. I replaced my tail lights for the US Red/Clears instead of the ugly orannge/reds...
My spare tyre well, car jack well and the other side (nothing in it) were all filled up with old water... musta been there for freakin yonks. Probably just need seals replacing in the boot maybe... dunno.
    6. 21
    7. 21
    8. 21
