Auto light settings
Kruzenvax
Hi all,
Sometimes ago there was a discussion here re. the setting for the Auto lighjts - e.g. how to prevent them "blinking" when passing under bridges. E.g. sensitivity vs the delay setting. Has somebody come up with a reasonable settings since then? My service is due and I'd like to have this adjusted.
I have done it this time~!
I told them to keep the sensitivity the same and just increase the latency (delay turn on). It seems that it turn on 2 secs after getting into the undercover parking, rather than 1 sec!
Thanks Taka,
So your sensitivity (your car's! :D) is 3/5 and delay is 4/5?
Thanks Taka,
Apparently I was told, delay is either short/normal/long.
I stressed many times to them not to change my sensitivity, so default is 3/5 and should be there.
