dash light help
dozer10
hi all, new to this site, hope you can help, i have a 89 hilux 4x4 Ln106 , the fuel light - timing light - battery light all come up on the dash at once, i had the alterater replaced with a new one which stopped it for a day but it started again. any thoughts on this.
okay, done a test on fuses and blinker and stop fuse were blown, fuse box in engine bay had two 10amp fuses with no power to them and the 7.5amp fuse has a weak signal - i dont know what these are as the box top is worn out. one of the wires going into the fuse box also has no power - it is a yellow wire with a red stripe going around it. any one know what these fuses are and where the wire comes from.
