Head light prob
Has any one had this prob my head lights won't come on it will switch to park lights but will not change to low beam and when I push the stick forwards the high beam won't come on but when I pull the stick back it comes on so I have no head lights ...could th be a wire that is not connecting prop because as I push the stick forward the high beam dash light will flick but still wont come on
I have a similar problem. Mine turns on to low beam but then exactly like yours, push the lever to high and I have no lights at all but the high beam light on the dash comes on and when i pull the lever back the high beam works fine! Please can someone shed some light on what may be causing this. Have checked the relay and it tests fine.
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
