09 Camry Problems?
Gab
Mate of mine is buying one for his next car
any common problems?
recalls?
Faults / issues?
seen the one about the accelerator pedal
mainly concerned about engine problems
where are they built?
That's a little scary that there's still Australians who don't realise Camry's and Aurion's are built right here in Australia and are in fact the "most Australian" cars when you look at local content lol.
The accelerator "problem" was found to be a non issue as in EVERY case it was found to be driver error and not that of the Camry. Furthermore though Australians built Camry use a denso supplied part which is designed different to the American Camry. The most prominent issue with 40 series is that of dash rattles which would be fixed by now under warranty (however this was fixed in the factory by 09) some communication issues with Toyota link in the Grande model and that's about as bad as it gets really.
