5me to 5mge
aaroncm
Like any conversion you will need ECU, loom, etc.
Given both engines are the same generation, ancilleries (like PS pump, aircon, etc) may fit, but if I were you I would get as many as you can from the donor engine.
The wiring loom may need to be adapted to connect to the body of the car, however if the 5MGE came from the same vehicle the 5ME was in, changes would most likely be minimal.
The best way to do any engine conversion is to get a front cut (or the whole car) of the donor vehicle, this means you definitely have everything you need to make the engine run
thanks for the help i also need to know if a 7mge intake manifold would fit on the 5mge as i plan on having a triple sidedraft webber setup and i can only find a manifold for the 7mge
    6. 21
    7. 21
    8. 21
