can i put 14 inch rims
was wondering if i can put 14 inch rims on a 13inch rim stud pattern on a ae101 corolla. does anything have to be changed to be able to. would the speedo be out
13" isn't the stud pattern, it is the rim size (4x100 is the stud pattern).
But yes, you can put 14" wheels on an AE101 with no problems (AE102s came with 14" wheels as standard), just make sure the get the appropriate tyre size so the speedo won't be out. Stock 13" size should be 165/75/R13, so if you're going up to 14" then you'll need a 175/65/R14 tyre (assuming you're staying with roughly the same width wheel)
      Camry 2007 Electrical Question
    2. 18
      Just purchased a 1996 Corolla AE102R CSX
      Tried everything won't run right
      Newbie
      Stolen Keys
      Stolen Keys
      2003 land cruiser troop carrier camping set up
      a/c pulley bearing replacement 'in car'
      2016 Hilux SR5 Coolant Issues
      Hi all!
