Corolla 1995 Seca questions
Hi, im new here and have a couple of questions regarding the Corolla 1995 Seca (which is mine btw)
1. Does anyone have a digital copy of the owner's manual ?
2. Does anyone have a copy of the fuse box diagram ?
3. What voltage and current does the light on the car ceiling (as in the one that turns
on when the door is open) need in order to run ?
4. Regarding the light I talked about in 3., can I buy a replacement bulb or fuse
at Supercheap Auto ?
thanks
thanks
1) Owners Manuals are pretty worthless these days, go down to Supercheap/Repco or go on eBay and buy a Workshop Manual (I recommend the Gregorys #271), it has just about everything you need in the owners manual plus a whole heap more to help out with home maintenance, and if it allows you to do just one thing at home (for instance changing brake pads) then it will have paid for itself in labour costs at a mechanic.
2) Diagrams for the fuse boxes should be on a label on the underside of the fuse-box lid. If not (and they're not in the workshop manual), let me know and I can look them up
3) Just about everything not related to the ignition in a car runs on 12V. The dome light (the light on the roof that turns on when you open the doors etc) will run a festoon bulb that you can buy from any auto-parts store, same goes for the fuse (which should be in the engine-bay fuse box)
      Camry 2007 Electrical Question
    2. 18
      Just purchased a 1996 Corolla AE102R CSX
      Tried everything won't run right
      Newbie
      Stolen Keys
      Stolen Keys
      2003 land cruiser troop carrier camping set up
      a/c pulley bearing replacement 'in car'
      2016 Hilux SR5 Coolant Issues
      Hi all!
