Calling All AE112R GENUINE Sportivo Owners...
New member seeking advice for parts
Hey thanks for the advice, unfortunately the part is discontinued, therefore cannot be ordered from there. -
Hi Alberto I don't know if they have what you want, but so far have had everything I needed. Genuine Japanese Car Part Imports - Amayama Herb -
Hi guys! I'm Alberto, I just finished importing a HZJ73 from Japan and I love it! The car came without spare wheel holder and it seems discounted so I don't know what do to. Someone knows where I can find it or what else works as replacement? I don't mind if is not oem part as far as it works 😅 I'm based in Brisbane if it makes some kind of difference Pictures attached as reference -
39
Pics of my Kluger steering wheel removal
What are you trying to say Don? _______________________________________________________________ skysmotor.co.uk sells the following products online: ac servo motor, geared stepper motor, stepper motor drivers, planetary gearbox and can be purchased online if required. -
14
1zz to 2zz
hey daniboy this is one of those situations where i’m stuck and going through old forums haha currently doing a 2zz swap on my zze122 wagon and i’m having a fuel pump not priming issue, any chance you could respond back 10+ years later -
Can I put a 2010 bumper on my 2008 Camry ?
I have a 2008 Camry altise and recently damaged the front bumper and i'm wondering if I can fit a 2010 sportivo bumper on to replace it. It looks like it fits I know I will need to get new headlights for it to fit but do I need to do any modifications or will all the plastic clips and screws line up ? -
5
Anyone else tried these seat covers ?
these seat covers look pretty good, but I've had bad experience when trying to fit some cheaper ones I bought online - they say custom fit, anyone else tried them ? Would love to know before I buy them, thanks all https://mycustomcar.com.au/ -
Digital Speedometer
Hi did you figure this one out? I have the same model and been unable to get it digital as well -
am2 fuse blowing
Hello, i have a 1996 starlet The problem is when i turn the key the fuse blows, and i have been looking over the wiring and can’t find any shorts or damaged wire. The car would not crank over because of the fise blowing. I found out that if i disconnect the transponder key ecu the fuse is holding, but as soon as i connect the transponder the fuse blows. So i wonder if there is something I can try out? should i just buy a new transponder box or is it something else i could try? and is it not kinda wierd that the box is the problem? I have looked inside the box and cant see any corrosion in the box
