Brake issues with 2024 Corolla Cross Hybrid
What exactly did the dealer do to resolve the issue? Was it related to wheel sensor/stability/traction calibration ? -
8
Faulty braking system in land cruiser 200 series 2016 model
Have you had a wheel alignment recently? Because if the rack is not true to centre when adjustments are made there is a sensor that detects it's not to centre & will apply the brake on the out of centre side. Also located under the centre console there is a yaw sensor that detects not travelling in a straight line it will apply the brake to correct the direction. A worn wheel bearing can cause the abs sensor think the wheels are not turning at the same speed. Loose wires on the crawl control can cause an issue. Ray. -
8
I believe the parking brake is still a drum (inside the hat of the rear brake rotor) -
9
2003 Corolla Conquest - Correct Brake Pads?
There are two different types of rear pad (and rotor) too. Toyota went all-out with the 9th-gens to make them as confusing as possible to buy parts for. -
MAF sensor cleaning
Step 1: Buy can of MAF sensor cleaner or electrical contact cleaner from Superepcobarn. Step 2: Unplug MAF sensor and remove from vehicle (usually just two small screws) Step 3: Clean sensor with cleaner as directed Step 4: Re-install. -
4
Hi @ZZT86 I concluded that was the ABS. But there was also update to the brake that they did when my car was with them.- 1
MAF sensor cleaning
My old Kluger (2006) is drinking a lot of petrol. More than it used to. It’s been slowly getting worse, so I thought I would clean the throttle body and the MAF sensor and see what difference that made. I’ve put into the search bar “MAF sensor cleaning“ and variations of that (To get any clues.) without luck. It either comes up zero results, or just a whole list of things about cleaning this or that. Can anyone point me in the right direction? Thanks, John -
Towing with toyota klugers
The Kluger‘s toe just fine. Your Kluger canto 2000 kg with a maximum of 200 kg on the tow ball. Which means you’ll probably be towing a single axle caravan in the 16 to 18 foot range. -
32
FUEL WARNING MESSAGE
Hi guys, I now have this issue. We are away in WA and NT when this issue occurred, I came very close to running out of fuel (still a quarter on the gauge) before I could get signal to investigate and also get fuel. It could be a critical issue when towing the caravan and you suddenly find yourself with substantially reduced range. thanks Geoff and Steve for your valuable information. Steve could you please let me know exactly where the sub tank fuel filter is, I suspect that might be my first point to check. -
Landcruiser 100 Series Price
Thought i’d pop by head in and ask. I’m trying to help my dad he has a Landcruiser 100 series that he’s thinking of selling it has a, 1FZ-FE engine, it has about 350,000 mileage on it. pros : jacked up suspension, long range tank cons : one cylinder is misfiring, needs new exhaust manifold gasket. Not really sure how much is a reasonable price to sell for. Hope yall enjoy the rest of your day
