Mk2 MR2 (SW20) Statistics
rhaines
MR2 Stats (not a full list and T-bars/rev4's will be heavier)
Body:
Weight = 1305 kg
Wheel Base = 2400mm
Overall length = 4170mm
Overall width = 1700mm
Overall height = 1235mm
Front track = 1470mm
Rear track = 1450mm
Ground clearance = 130mm
Wheels :
pcd & offset = 114.3 & 45mm
Width = 6" front 7" rear
      Code P004B
      Upgrade from 2012 to 2023
    6. 3
      Towbars
    7. 5
      ASV50 Camry Head Unit Options
    9. 2
