98' Camry - Multiple FOB Remotes?
DwayneM
Hello,
Does anyone know how to program more than 1 keyless entry FOB remote for a 98 Camry?
I did have 2 working remotes programmed, then I had to replace battery in one, but when entering programming mode I can only seem to program one or the other.
Tried pressing the buttons on both simultaneously but only the one I pressed first was programmed.
Any help would be appreciated
Is it the kind where you put the remote fob in to the socket in the glovebox or the later one?
Generally with remotes you only program one at a time - setting one shouldn't wipe the other out from the system (that generally only with aftermarket systems I have found)
No glove box socket in my camry, just ignition key lock/on/lock x3 then security light goes solid, hold remote button and it blinks indicators to tell you its programmed then remove key to test
I have 3 working remotes, just wanted a spare programmed remote to go with my set of spare keys
