Water pump and related accessories replacement costs
TCam
What exactly is involved with changing water pump, thermostat and all belts? Any ideas of cost for Camry 2005 Altise Sport. Would it also be prudent to up grade alternator at same time? A weird rattle appeared recently. Intermittent. Lasted about ten minutes this Saturday. Appeared to be coming from alternator. Has been suggested it may also be water pump. Should timing belt/chain be replaced as well?
Ok, thanks. Was quoted around $350.00 for water pump & $450.00 for Alternator, not counting labour. That clears up everything for me very well. Shall get spring on tensioner replaced whilst at it. Thermostat too. As the rattling noise has just started, even though briefly intermittent, decided to act quickly, get some research in and fix. Thanks again.
    6. 21
    7. 21
    8. 21
