Brake issues with 2024 Corolla Cross Hybrid
No, there wasn't any issue to resolve. I did a test drive with a mechanic and could reproduce the noise by sudden braking on a speed bump and it was the ABS. Hope that helps. -
Burning smell
Hi I have only had my lc300 for 1 day and it smells of burning rubber, is this normal? -
Location of Flasher Turn Signal on '22 Hilux
Hey guys! I have a question regarding the exact position of the Flasher Assy, Turn Signal on the Toyota Hilux '22 RHD M/T. I tried to look for it in an online catalog parts as well as news and videos online, but still no luck until now. Does anyone here know where it was placed or maybe have replaced it before? Thanks in advance. -Jim -
1KD Stock Boost Pressure
I went for an after market Turbo on my 2006 after few years of owning and new turbo boosted to 16psi which is bit higher than factory. this upset some of the sensors and put engine into limp mode every day i drove it. backed off turbo a touch and has been running fine for years now. -
Seat change
I did a seat change to my front hilux and also did a re pad for rear seats which were rubbish hard. few years latter during rego i was warned that if insurance ever seen from seats they would be asking for Engineers inspection report or it isnt covered. -
16
Connecting spotlights to high beam on 2011 Hilux
I did my high beam lights on my 2006 (bit earlier) and from memory it was a strange positive earth or something like that just of headlights. -
Vehicle tool kit
Yes or Ebay. I suspect like mine when i took it for 1st service disappearance of jack and tools, there is quite an after marked for 2nd hand jacks and handles ext -
KX-R roof rails
Hi Guys, Just found this great group about Kluger. I have a quick question if someone can help. Someone sold me the Toyota roof racks and I thought I could fit them myself, but when I started installing, I found I could not fit them into the provided fittings. See the picture below. Can someone please recommend what I should do? Thank you in advance. -
7MGTE Air mass sensor/meter
Hi, Looking for a Air Mass meter for a 89 MA70 Supra 7MGTE
