Roundy's ST185
Roundy
Hey Guys
New here and thought i would make a thread about my pride and joy (other then the gf of course ;) )
1990 Celica GT4
Mods
Engine
Garrett GT2871R Turbo on Custom Manifold (Set to 10.5psi)
3" Exhaust from turbo back
K&N Panel Filter
Group A W/A Intercooler
Body & Wheels
Group A Bonnet and Front Bar
17" Rims
Suspension & Brakes
KYB Gas Shocks
Kings Low Springs
Whiteline Adjustable Rear Swaybar
Whiteline Adjustable Rear Strut Brace
Noltec Camber Bolts All Round
Wheel Alignment
-1.25° Camber All Round
0mm Front Toe
1mm Rear Toe
Slotted RDA Rotors All Round
Braided Brake Lines All Round
Ferodo DS2500 semi-race pads front
This has made 142.2awkw in January (and 131awkw in july but lets not mention that :rolleyes: )
and also done 1:18.0 around wakefield, and i need to grow bigger balls :rolleyes:
Also did 9.71 on the 1/8 at Bodangora @ the Toyota Nationals, tires grip better then the clutch LOL
Future Plans are (in order of importance)
New exhaust manifold (old one cracked)
Coil Overs
ECU to take full advantage of Turbo
2.2l Stroker (5S-FE crank and pistns and rods to suit)
Larger Turbo
Bigger Brakes
And of course some pics!
Dyno Graph (January 2.5" Dump Pipe)
This is her with the old Rims
And this is as she is now (cept dirty)
Hey guys,
update:
Started my preparations towards the new exhaust manifold. dropped off the stock manifold to get a head flange cut, could be ready as early as next week!
Priced up the steam-pipe (butt weld fittings if u are looking for them) in various sizes, now need to pick a size and use it!
Anyways the very next thing i will be doing to it will be a oil change, and quite possibly a slight advance on the ignition timing to see what it does (should give slightly more grunt and economy)
  • 4 weeks later...
Hey Guys,
Competed in the Huntley Hill Climb on the weekend. Was AWESOME fun, i would strongly recommend it to ANYONE who wants to have a go at club level competition.
The course is, to be honest, fairly tame in a street powered car, i was flat most of the way bar 1 corner, which i always goofed up!
My best run of the day was a 32.51 (tho my 4th may have been quicker, i haven't seen the time) I think (and hope) there is heaps more in it yet, i just need to learn how to launch it properly, and get a stronger clutch!
on my 3rd run i tried for a big launch, i probably didn't release the clutch fast enough and (clutch) smoke ****** out of the bonnet vent :blink: woops!
In my wisdom i forgot to take a camera :whistling: but a couple of other of the Toymods crew were there and got some pics. Once they have uploaded them i will post some up here.
I will definately be back there again some time, and hopefully with some launching skills, and porbably a stronger clutch!
Cheers
Nathan
