Hey guys, i drive a 2002 SR5 Hilux Dual Cab 2,7L 4x4. The 4x4 gear knob should sit in the "H" possition when normal driving. As that will give you high range when cruising normally. If you want High range 4x4, all you have to do is push the button on the side, and if you want low range (which is only an option for 4x4) you just pull it back to "L". If kept in neutral "N" the car will be in that gear "Neutral" and wont go anywhere. But anyway i get about 400kms to a tank city driving and if its all on the freeway it is normally 450-500kms. Not wonderful fuel economy, but for a little 4-cylinder engine pulling about 2 tonne of vehicle, it does quite well. Ive owned her for about a year and a half now, and since then ive dropped the oil a few times and changed air, oil and fuel filters and it has never needed any work what so ever, Hilux's are worth the money.
