SOLD!!
From march 2024 in Perth Australia. For sale Toyota Landcruiser Troop carrier hz78 4.2 L turbo diesel, 6 seater, year 2000 + odo 395000 km but motor only 80000 km. Serviced every 10000 km. Some small supervisual rust spots and only a small dent in rear quarter panel.
Send email for pictures and more info.
Solar panel for off grid camping.
Licenced in wa, rego until 18/02/2025!!
QVC report (silver) available.
Perfect suitable for off road travel
Price Aus $29500 + payment by banktransfer or TranferWise. Cash €17500 only in Euro's.
Mechanical
Gear box and transfer case rebuild at 300 000km with new gearbox heavy duty output shaft, heavy
duty single piece transfer case input shaft, upgraded 5th gear and heavy duty thrust washer
Engine rebuilt at 315 000km
Full rebuild due to1 cracked piston.
Heavy duty turbo piston and hdt conrod, rebuilt head, rebuilt injectors, rebuilt fuel pump to turbo
specs with boost compensator, rebuild starter and alternator, new water pump, thermostat, hoses, new custom high flow mmp turbo set to 16psi, custom topmount intercooler with fan, oil catch can provent 200, drain to the sump new fan visco hub.
3inch Manta exhaust pipe with high flow muffler, very quiet, close to original sound.
4H4L + front hubs manual lockable.
Under chassis
2x 90 L fuel tanks
In 2023 All rubber bushes new + all uni-joint on drive shaft have been done.
2inch lift with tough dog Front shocks and efs xtr rear shocks,
heavy duty leaf springs and coil springs.
New wheel bearings all round
Front swivels hubs seals.
Sunrasia Steel rims with bf K02 285/75r1 6
With 40-50% tread left on tyres
Interior
Sound proof and heat proof protection on floor, tinted windows,
dash mat, central locking with remote (2 sets of keys)
Manual side window handles.
Radio cd player + usb + bluetooth for hands free phone.
Exterior
Full length custom alloy roof rack with 160w solarpanel at the front, arb awning on left side, arb roof
top tent that opens to the rear.
2 Led spot lights on roof rack and 2 way aerial connector for all electrical so the whole roof rack
can be removed in minutes.
Custom side ladder.
Arb dust proof air connector on rear bumper to inflate tyres.
Wheel arch flares
2 led spot lights on ARB bullbar
Custom all steel bonnet with v8 intercooler scoop.
Electric steel cable winch 9500 pound with remote cable.
2 spare tyres on steel rims. One on the backdoor and one on roofrack.
Rear left and right side windows replaced with Alu doors. Lockable by remote.
Rear setup
Two full length drawers.
Custom fridge slider with Waeco cf50.
60L water tank.
Gas struts on rear doors.
Front runner rear door table.
Gascooker + 2 kg bottle.
Electrical
09-2023 - 2 new batteries.
Dual battery system with Redarc smart solénoide.
Solar panel 160 W on roofrack with redarc converter and display mounted in the cab, charging both batteries.
lsolator switch under bonnet.
Switch on dashboard to jump-start itself from secondary battery
350amps Anderson plug on bullbar to fit jump leads.
Electric winch with steel cable.
Led spotlights
Twin 6inches Led light on roofrack with switch on dashboard.
ARB air compressor integrated in rear quarter panel with air connector on rear bumper + switch on dashboard.
GME tx3100 two-way radio in roof console.
Reverse camera integrated in roof console.
Engine management system with display in cente console that shows egt, coolant temp, oil pressure,
boost pressure and both battery voltage. Data can be downloaded to make graphs.
All interior lights are led.
Usb plugs on centre console.Fridge anderson plug at the rear with switch on dashboard.
