tomee
    Rav4
    2010
  • ICQ
    Tomee
4,396 profile views
tomee's Achievements
Community Regular
Community Regular (8/14)
  1. looking at purchasing an Eonon headunit for my 2010 rav4 which also has a factory fitted reverse camera Has anyone successfully made the Eonon work with the factory (fujitsu) reversing camera?
  2. hmm so the whole thing is only 2.5" according to your measurement compared to 3.8" / 96mm on the amazon one are you able to take a pic? did some research on the tool number and it is 64mm so i suspect amazons measurements are wrong. i purchased the part from amazon and hoping it fits. does anyone know what oil Toyota uses on the rav4?
  3. hi, can anyone tell me what size oil filter cap tool i need for my 2010 V6 rav4? this is for the american model so not sure if it will fit models sold in Australia http://www.amazon.com/gp/product/B0015PK3AG any help appreciated
  4. does the starter make the usual turnover sound? or does nothing happen?
  5. whats the deal with the TRD SC on a stock 1zz? is it a straight bolt on with no mods? what about ECU?
  6. hey,
    its only for pioneer units. not the toyota fujitsu ones
  7. Hi - I noticed you were able to fix Tarago radios when they won't accept a sec code and just read 'HELP'. I would be extremely grateful if you could tell em how? Thank you for your time,it is much appreciated!
    Faith
  8. sorry to bump this guys but ive got a regular 02 levin corolla, and wondering what oil you guys are using? also does anyone have a diagram of where the fill and drain plugs are for the gearbox?
  9. i got a timing belt kit which included belt, tensioners, cam gaskets, drive shaft gasket aswell as new waterpump for $310 trade price then paid a mate of mine to do install it for $250 just to give you an idea i did the valve covers myself. i think the cost for gasket and bolt gaskets was like $50 each side the front one is ***** easy to do. the rear one requires some time and patience as you have to remove the intake plenum and wiggle the cover around to get it to lift off.
  10. anyone able to tell me where the knock sensors are on the 3vz?
  11. looking at this chart, there is no 55 http://www.troublecodes.net/Toyota/ so im guessing both oxygen sensors? 5 + 5? if it were code 55, wouldnt the first 5 be half second bliks, then the 2nd digit would be faster blinks? if it is the knock sensor, where is that located?
  12. ok i got the codes and i get 5 blinks then 1 sec pause then another 5 blinks.... then it starts again would that mean its pulling 2 x 5 codes? or a code of 55? where can i check these codes to find out what it is?
  13. hey guys, i need to pull some fault codes for a 1996 V6 camry (3vz-fe) my CEL is comming on and need to lknow what it is. i remember doing it years ago but forgot what ports to short in the diagnosis port thanks
  14. hey guys, driving home tonight i noticed my windscreen is leaking under the sunvisor. i was wondering can anyone tell me how to remove the seal, to either see where the leak is comming from or seal it up? the car is a 02 corolla thanks
  15. what kind of noises?
