Programming a new remote transmitter for XV20 Camry (1998-2000)
Using the OEM black transmitter with single grey button.
1) Sit in drivers seat. Make sure doors are closed and headlights off.
2) Insert key, push in and turn key to ignition on position (not starting engine) then back to lock position. Do this three times within 5 seconds finishing in the ignition on position on the third turn.
3) The Security light on the instrument display will light up for 5 seconds. Press the button on any remotes during this time and the car will lock and turn on hazard lights once.
4) Turn key back to lock and remove.
5) Test all remotes work to unlock and lock car.
* I believe up to four remotes can be programmed at once.
