altezza light bulbs
pujo
hi to all, my chrome altezza rear tail lights just arrived. it gave me a real hard time trying to remove the stock tail lights. when i did, i found out that the bulbs socket are different. the altezza did't come with bulbs for some reason, only the blinkers. does anybody know what type of bulbs these altezza's use?
cheers, pj
without seeing the different socket it is hard to guess what kind of bulb you need.
just walk into autobarn repco supercheap with the socket and show the person there to give you the bulb that fits inside it.
normally you just reuse the bulbs from your original lights
the wedge type seen here http://www.trdparts.jp/release/07-winker-bulb.html
thanks kcorro, the one's that are actually on the stock lights (wedge) are different. i needed the PY21W one's so i got them from supercheapauto. would the LED's look nice on these altezzas?
i tried the led bulbs on the altezza, the blinkers bulb blinks a lot quicker than it use to be and the brake lights, the dash light will only turn on when i brake at nite and after a 10min drive, the service light will light up in the dash.... :ph34r:
    2. 14
      Hi from Wagga
    5. 2
    6. 2
    7. 2
      Engine oil dipstick reading
    9. 1
      Landcruiser 13B Engine Swap
