Water in the headlight
Brad!
Over the weekened I noticed that my right hand side headlight had gathered condensation and there was a small amount of water in the bottom.
For those in Sydney, rain on Saturday Night was full on, not sure if this helped hinder the situation.
Sunday washed my car, seemed like there was more, and after this afternoons water I am definitely sure the water is still coming in.
I have HID’s but the hole that is there is only big enough for the wires to run through.
Has anyone else had this problem? And what is the best way to remove the water/condensation that is in there.
Car is booked in for service, warranty repair in 2 weeks so hopefully the light is replaced
Any suggestions appreciated.
try leaving your headlights on while driving for a long time.. the heat from the headlights might help dry it out?
but then again you're running HID's. they produce less heat then your normal halogen globes. you could try blowing a hairdryer through the socket area =D
      Upgrade from 2012 to 2023
    4. 3
      Towbars
    5. 5
    6. 2
      ASV50 Camry Head Unit Options
    8. 2
    10. 1
