Squeaking Dash 2007 Corolla Sedan
dougone
u sure its not somethign u put inside those drawers and compartments?
I used to have it on my hatch, But its probably from the things i put in my dash compartment. I hvnt heard it since i took those out. Mines a hatch btw.
No it is definitely the silver trim. If I push against the trim with a finger it makes the same noise. As I drive and go over bumps in the road a get that squeaking or perhaps better described as a sort of clicking noise. ZDrives me nuts. :(
I have a 07 ZZe122 which is also making a weird noise from the dash.
On its 20k service i asked them to have a look at this and they think its the clutch pressure plate
Might be worth having Toyota having a look at it.
Nope....mine is an auto....the car does only makes the noise when it is warm or sun has been on the dash.....and I don't have an e-tag.....certain older e-tags send an annoying noise down the windscreen that seems to come from debing the dash.....it is definitely the silver trim
  • 4 weeks later...
We have a corolla conquest hatch 07' and it doesn't have any noises (Apart form one in the back where a plastic panel is lose, i think), but then again the dash setup is different.
Oh and you have the same name as me!
I have a 2007 corolla ascent also, It is a hatchback model, and i have only recently noticed a gentle rattle coming from the dash as well. Nothing is rattling in the glovebox or any compartment. It is worse when i have a passenger and when traveling at around 80kms/hr. It is not a mechanical rattle, just a interior rattle, as when the expansive dash is pushed down, it stops rattling.
Is yours a sedan and a 152? I find I can push on top of the dash or on the silver trim around the stereo and voila.....squeeks!
