rim specs
ChynaMan
ok im a total numbnut when it comes down to all this PCD OFFset crap ahaha
ok the rims im attending to get
http://www.bsawheels.com.au/users/ProductDetail.aspx?id=277
the 18's ... will they fit with no probs???
if that doesnt work then the specs ... size=18x7.5 , hole= 10, PCD= 98-120, offset= 35-45, centre hole = 73.1...... i just read that centre hole for the corollas are 55... ???
much appreciated guys ....
alot of rims have a big centre hole to suit more cars . then fit hib rings to them from 54 to 73mm thats my ones btw unless you car is a sportivo you leagally can't put 7.5inch wide rims on the car only 1 inch wider what rolla do you have ?
PCD is 4x100
"PCD OFFSET cr@p" isn't very difficult to understand, you just have to spend 15 mins or so reading it...
Micky_tee has a set of those in 17" for sale. Guaranteed to fit. With tyres.
Micky_tee still hasn't sold rims yet ?? the Hot white ones ?
i have a 1zzfe corolla hatch
dont really car if its illegal or not .. it looks good with 18's :P ...
They're still in the garage :P
those rims have been on my mind for ages ... damn xmas ... or they would be mine
      Upgrade from 2012 to 2023
    5. 3
      Towbars
    6. 5
    7. 2
      ASV50 Camry Head Unit Options
    9. 2
