Bluetooth In Kluger Grande
Zirion
How do you want me to explain... it is in the user manual.
What model *(Grande or KX-S) you are having again.
It is simply pairing the phone to a device (car phone) and it is different in different model of phone. Suggest to look up how to pair up blue tooth devices on your phone as well. It is the exact procedure as your bluetooth headset.
look in your phone manual on how to activate bluetooth...
but before you do, make sure your phone DOES have bluetooth... otherwise what model is your phone?
Nokia's work best with the Toyota blue tooth devices.
Found the easiest way is to turn the blue tooth on your phone on, and make sure its discoverable.
Turn the car on and sit there and wait.
You will get a prompt on your phone saying that hands free is trying to connect.
Accept this, and when it asks for a pass code type 1234 (Might be different, corolla is 1234)
When it says do you want to automatically pair, say yes.
Once this is done you should have a BT symbol in the top left hand corner. (once again depending on how the setup is).
From now on, when you turn the car on, it will automatically connect to your phone without asking and user intervention.
