dvd audio
brother1
You can if the front radio has an aux socket on the head unit or aux input at the rear. To find out, press the front radio source button and if AUX appears, then there is provision for it. If so connect via rca 3.5mm plug from Dvd earphone out to front radio aux in.
Cheers
Cheers
No RCA provision........ :(
Cheers
We test drove the kluger and also the calais V, we were really dissapointed in the klugers dvd, two reasons, a: As mentioned, the sound doesnt go through the audio(it does in the calais v), and b: If in use, try using your rear vision mirror, its basically useless, whereas the one in the Calais V, you can still see the road while in use.
Therefore we opted not to go for the grande, apart from the faux woodgrain...yuk! kxs has all we need and then some.
We will probably look at a headrest dvd option built in as we intend to do a few country trips, apparently these are available for the kluger, nunawading toyota has more info on this.
