Kluger Sat Nav
bodin
I admit its still fairly new to me but I am having trouble with the Sat Nav Guiding me.
After setting destination it tells me to go to the start point, and it tells me I have
arrived at my destination when I get there, but nothing in between. Any ideas!
Hi bodin. So no "Turn left in 100 meters" "Take 3rd exit" etc..... What does the screen look like? Is there a heavy blue line on the screen that you are following? Does a diagram pop up on the right hand side now and then as you approach major turns or freeway exits?
rEEza, Yes there is heavy blue line depicting the route, but havent noticed diagram on RH side
You do hear the message like "please proceed to the highlighted route" or "the guiding will start now"?
Yes and You have now reached you destination (when I arrive).
Which GPS system do you have bodin? The Grande one or the upgrade accessory?
It's a very strange problem your having. :blink:
That is strange indeed - unless your route is straight wih no turns and destination is 100m from the starting point... will have a look at my unit settings tomorrow
KX-R Upgrade
Bodin
I am not sure if this will help as I have a Grande which came with GPS, but it sound to me that after you have selected the destination, you have failed to select a route (button on the left bottom of screen on the Grande). Therefore it would make sense that as it only knows starting point and destination it cannot give you instrucvtions during the trip.
Bodin
I thought you had it there SamF, but alas it did not work, thanks for the reply
Nice, so DID your screeen functional when you drive (before it got fixed @ dealer)?
What I am getting is that people are thinking of tricking the speed sensor to the sat nav so the unit thinks we are doing less than 5kmh, but in this way (according your experience) that the sat nav will not work at all....
So it is not a solution then :unsure:
Edited by Taka
