My fans arent working causing my car to over heat,
Do any of you guys no how to fix this??
Thanks in advanced for any feed back.
Firstly check if the thermal sensors or switches are working,(I think)You should have one located to the engine side of the head.
as a failsafe if you disconnect the switch your fan should turn on..this would eliminate a faulty fan
to check the fan just hand turn it,if u hear any noise or it feels loaded then its ur fan!
turn you air con on & if the fans not kickn in then it may the switch..
Good luck buddy
      Turboed Corolla Overbuilt?
    2. 3
    3. 3
    4. 0
    5. 6
    6. 18
    7. 5
      Tow bar
    9. 3
    10. 0
