C66 vs EC60
Just thought I'd post this if anyone was interested.
As you know in early 2009 there was a revision to the gear ratio for manual corollas.
The former ratios in the C66 were:
- 1st gear ratio :1 3.166
- 2nd gear ratio :1 1.904
- 3rd gear ratio :1 1.310
- 4th gear ratio :1 0.969
- 5th gear ratio :1 0.815
- 6th gear ratio :1 0.725
- reverse gear ratio :1 3.250
The revised ratios in the EC60 are:
- 1st gear ratio :1 3.538
- 2nd gear ratio :1 1.913
- 4th gear ratio :1 0.971
- 5th gear ratio :1 0.818
- 6th gear ratio :1 0.700
- reverse gear ratio :1 3.333
09 Rollas will dyno better >:(
And I want that 6th gear ratio!!!!!!
yes, and the later ones are terrible with that stupidly low 1st gear and too tall 6th. the 6 speed box now only has 4 useful gears. 6th gear change was almost certainly to help published economy figures, but the engine really struggles with it in hilly areas, so you are constantly dropping back to 5th or even 4th. it becomes even worse if stupid owners fit bigger wheels/tyres
    6. 21
    7. 21
    8. 21
