Replacing courtesy Light Button
Shidas
I found out that my courtesy Light didn't turn on when opening my rear driver sided door in my SV21.
I used my multimetre and found that the button is no longer working properly, as i looked at the button i find the Positive terminal looks solidly attached to the button, and as there isn't very much slack in the wire I really don't want to splice the wire.
So i'm asking if anyone that has removed it before if there is a easy why of removing it before, I try and find a way to remove it and chose a harder way of removing it.
Any help would be appreciated
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
