valvoline oil
GK200
$80 Bucks, man your getting shafted. It must be old as stock cause the new lable/branding came out yonks ago. $27.50 is below cost for sure. From memory RRP is $55+gst or close, but hey thats a bargan cause the lable changed but the oil didnt and it should be fine to sit around for years (technically) without going "off" Its quite good oil that to. I used that SynPower in my ex Commodore and it make it run better and when the oil change was due it was a lot better looking then previous "pov" oils.
