Whiteline rear swaybar.......
vvti16v
Most people would know that my car is going back to stock and in the process of installing original parts back the rear swaybar was removed and it was broken at the welded joint....I have been getting a clunk noise when the car twist (going up driveways) and i though it was a loose bolt on the swaybar but it was a broken swaybar. So if people have the same noise you should check it.
