Hi guys,
New to the Toyota forum and new to the Toyota brand with a 2003 Camry Altise.
I am wanting to know how to replace the lights behind the aircon temp graphic. The one that goes blue to red in an arch to be specific. The light that does no work illuminates the red park and the hazards button. I used to be able to tap the red part and it would come on but it does not work anymore. Also how to change the light in the ignition barrell. What type of lights I need would be a help as well.
Thanks in advanced for any information provided
Cheers
Hi guys,
Cheers
Havent Done this in a while....
There are two pieces of frames. One surrounding the Radio and the other is with the Aircon Nobs
First you need to remove the frame around the Radio.
To do that put the screw driver in between the two panels and push towards you. theres two clips on each side, (about 2 cms from the edge.
Then pull the frame out after removing the speed alert and clock cable.
Remove the Radio
One thats done remove the Cables from the back of the Air con Frame. (3 Cable from Memory)
Then theres two clips on the side and two on the bottom (from Memory)carefully remove the frame.
Then u need to open the white surrounding and change bulbs :)
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
