Smoke/Reconditioning
megalux
Hey all,
I bought a 1993 Hilux LN106, 2.8 TD, 4wd, 18 months ago. Was only supposed to be a short relationship but now I want to sweeten her up.
Anyways, I am blowing some large amounts of smoke under acceleration but not under idle. What should be the first things I should check? Have done regular oil changes/ fuel filter and she has 325k on the odometer.
Is it worth just going for a full recon or not?
  • 6 months later...
Hey all,
Injector Clean? A simple compression test can tell you if you need a reco.if you have good compresion then chances are its a problem elsewhere.
Hey all,
Sorry i just noticed you have a TD.. Aftermarket turbo's arent reccomended on these diesels. you will shorten the life of the engine dramatically.
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
