Dirty Hands AE 82
MY 88 AE sedan project
well Ebay is a toyota owners friend sometimes
lucky
for $100 I got an
as new clutch master cyl normally new $100
a full interior back and front seats (wreckers wanted $75/seat)
lamps and plastic interior bits
now its ready for safety cert and rego
work still to do
windscreen chips
a timing belt
a decent radio and speakers
got the fuzzy dice
took the car for a run today
now the clutch slips in higher gears
repco want $180 for a clutch
more work
what a crock
bought mine off ebay for $120 new
today took out the engine and gearbox
and it only took me two hours
doing the clutch and timing belt while the motor is out
dam easy car to work on so far
now it needs engine mounts
Repco dont have a listing for the front engine mount
they have one for the rear
can anyone clue me in on the front mount where to find one ?
what i normally do is get the part number from AutoOne, then if they dont have it in stock go to repco/supercheap and magically find the same part..
anyways check the below link to some partnumbers for enginemounts for 4A ae82's
http://www.toyodiy.com/parts/p_G_1986_TOYOTA_COROLLA_AE82R-EEHDCQ_1107.html
I use to run E10 in my AE86, it ran pretty sweet with more advance timing (the 4AGE had a 10.3 CR).
however with in 3months the fuel filter and rubber fuel hose started to leak/split, might have just been luck?
some people say the plastic in the older carbs maybe not last
thanks for all the replies
I will give Ethanol 10 a miss
carbys are bad eneough when working ok
got the engine mounts from repco
they even gave me 10% off the whole bill
rear mount repco part number MT8359
front mount is a kelpro part number MT8248
timing belt was $20
very easy to replace the timing belt with
the motor out
the project continues
another question
The rear drums hub seem frozen on
wont come of with a hammer hit
are you supposed to back of the adjuster ?
the drums should just come off, handbrake still on?
normally i remove the drums to adjust it.
if u want an upgrade, the AE82 Twincam have front vented disks and rear soild disks
Found pics of my old 1988 AE82 Series 2 Twincam hatchback.
had a AE92 4AGZE with 5spd LSD E58 gearbox.
Nevo Pully running 14psi, 2.25" cat back exhaust (not too loud), VR4 FMIC & home made CAI w/ k&n panel filter.
Superlow springs, kyb shocks & rear whiteline swaybar.
Best $2500 ever spent.
well it passed roadworthy
and rego checks
drives pretty good for an old car
rear solid discs
what parts do you ask to do the conversion to rear discs
do you have to change the swing arm or master cyl
or can you fit the rotor to the
existing stub axle
Edited by dirty hands
      ASV50 Camry Head Unit Options
    5. 14
      Hi from Wagga
    8. 2
    9. 2
    10. 2
