Aurion Tyre Pressure
william777
Actually the more travelling you do in one hit increases tyre heat and pressures, so there is no need to increase pressures.
I don't agree ...
I drove for 400km on a highway using 100% cruise control and could touch the brake rotors as soon as I came to a halt. The tyre was not the same temperature as when I arrive home from work. If you don't turn corners or brake, you are generating less heat and tyre pressures will not increase as much.
Plus, the tyre pressure will stabilise after some period of constant driving (say 15 minutes if you started cold), at which point the tyre pressure will increase no more.
