Corolla 2007 on door trim removal
stretch1000
Just trying to get as much info as posible on how to do this. I have found three screws holding it on. Two behind the door handle and one behind the door latch. Now i have tried to pull the door panel off after removing these screw but it does not seem to be coming off. How much force do i need to get this off or do i need a panel removal to help. Any help or photos would be great. Also advise on what type of speaker fits in the door would be great also.
Hey Man,
there is a fair amount of force required on the 1st time you take it off (i know from my car install days). Also note, you should disconnect the 2 cables running the door lever or, alternative, unhitch the door handle and leave it hanging :)
PS: Corolla ICE upgrade << Check this for ideas:)
Hey Man,
Thanks for your reply pete, the photo's are invaluable and help alot. How did you go about fitting the speakers in the door with those dam pop rivets. I take it you just drilled them out. What size screw did you have to use. Also how do you disconnect the door handle, is it just a push fit.
Cheer's Craig
Hey Man,
Drill the pop riverts and make a custoemr speaker mount out of 8mm MDF. To nail it in place, I used some long bolt and nut combos from bunnings (about 5-6 cm long)
You can fit 6.5" speakers all round
Hope this helps ;)
