What size wheels for 2000 Camry Touring?
h4l
Hiya,
I just picked up a 2000 Touring Camry, and the tyres will need replacing in the next 6 months. It currently has the factory 15" alloys and some chunky 205/65/15's.
I'm considering a +2 wheel upgrade and from reading elsewhere can see that 225/45/17's will fit.
So my next question is about the wheels, I'm thinking 17x8 but cannot find any info on the recommended offset.
I was looking at these wheels that are $150 ea, and have a 36mm offset.
Would they work?
Edited by h4l
8in wide wheels WILL cause scrubbing. Depending on the offset you will either need spacer to stop them hitting your struts or you will need to roll you rear guards.
I don't want to bother with spacers, so perhaps a 7.5 inch rim?
      Towbars
    2. 5
      ASV50 Camry Head Unit Options
    5. 2
    8. 14
    9. 2
      Hi from Wagga
