BC BR Coilovers Knocking Issue
Hey guys. I got my brand new BC BR Coilovers installed in my 2003 Toyota corolla sportivo 2months ago and there were no problems and everything was all sweet handling and everything. However 2 days ago a noticed a slight sound at the front left of my car but thought nothing of it. It then started together a tad bit louder. So I checked out the front left coilover, nothing was loose so I changed the damper settings to full stiffness at the fronts. The knocking noise was Way louder and sounded pretty bad. So I change the settings back to full softness and the sound only knocks on bumps on the road but no sound happens during turns, only bumps. Anyone had this problem before? Any suggestions on what I should do?
Try tightening the bolt (silver one) that sits just under the stifness adjustment knob. I found that when that was loose some knocking occurred.
Let us know how it goes,
Alf
Ill try that but I had a look, how loose would it have to be? Because I tried moving it with my fingers and it seemed tight. But ill try it with a tool.
Alf
THANKS MATE! this actually really helped. The knocking is gone and the bolt was actually loose.
Thanks Again
Dan
is it all good now mate? im about to order a set of bc racing coilovers for my 2006 corolla, how much did you get yours for?
      Upgrade from 2012 to 2023
    5. 3
      Towbars
    6. 5
      ASV50 Camry Head Unit Options
    8. 2
