3Y carby mods
beergut
G'day all,
I have an 83 2wd Hilux into which someone has put a 3Y motor.
When I took the carby off I noticed it was too big for the manifold.
The spacer plate between the carby and manifold hangs over the edge of the manifold and has been redrilled to bolt the oversize carby base to it.
I want to get a 3Y converted Weber carby from Recarb and need to know it will fit to the manifold.
I think it's probably a 3Y manifold with the old 18R carby attached to it but I need to be sure.
Does anyone know what the hole spacing is on top of the 3Y manifold so I can check?
Any help will be appreciated,
Thanks for reading
      Ae92 genuine low ks 70800
      Code P004B
      Upgrade from 2012 to 2023
    7. 3
      Towbars
    8. 5
      ASV50 Camry Head Unit Options
