URGENT HELP REQUIRED (CAI RELATED)
MotoMan
Does the TRD cai have a little nipple on the bottom for the stock vacumm line?
Ive go the injen and the only thing left is to plug in the stock vaccumm line... but ive got no idea where to disconnect it from etc...
any help, pictures anything would be greatly appreciated
is that the small bit of pipe that comes out from the back of the main pipe?
as the design of the AEM is very similar, I blocked mine off by cutting the supplied vacuum hose (it connects to the lower VSV in th US models) just longer then the bit of pipe and screwed a bolt into the end of it (cost about 50c from Bunnings) take the tube in with you so you know the right size to get too ;)
Edited by Blue_Stivo
