Aurion ATX spare key
straiv
HI Guys
Urgently need your help. I have lost my spare key for my 2008 aurion
Can i buy a transponder key on ebay and programming using the below method
Procedure to program new master key;
Hop in the car, close door. Insert existing master key into ignition barrel (don't turn) and remove again, repeat this 4 times (ie: in>out>in>out>in>out>in>out>in). Leave the key in the barrel and open/close the driver's door 6 times. Remove the key, insert the new key to be programmed and leave it there for at least 60 seconds. And that's it.
if not please advise
Thanks alot
When i was organizing a spare key i bought the Key of ebay for $30 but the method listed above didnt work.... i had to go to the toyota dealer and they did it for me for $25. I also bought the key less entry fob of ebay for $60 and was able to program that myself. Much cheaper then the almost $400 Toyota wanted from me for the key and fob
Hi Guys i bought my key on ebay and went to a locksmith to cut the key at $20 dollars
After that i try the door method that i mention earlier on and my key is able to start engine and drive
Cheerts
      Towbars
    2. 5
      ASV50 Camry Head Unit Options
    5. 2
    8. 14
    9. 2
      Hi from Wagga
